pb on scan with PCTV 300i : no DVBT Found
1 post
flandrinus
flandrinus
Sat Apr 25, 2009 8:46 am
#1 by flandrinus
hi,
i'm using pdvb 6.06 & BDA drivers for PCTV 300i. When i perform a channel search. PDVB never find any channel...
the card seems to be installed perfectly.
Help Pls
:P
  • Sat Apr 25, 2009 8:52 am
1 post
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 9:45 pm
