New Hauppauge driver -> Level=100 Quality=0
paulfarre
paulfarre
Tue Apr 28, 2009 5:56 pm
#1 by paulfarre
Just upgraded the original Hauppauge software for my HVR4000 to WinTV7. Driver package version 2.123. BDA driver file version 5.3.2600.5512. Now all channels show Level=100% and Quality=0.
Anybody got a solution - apart from going back to previous version ?
  • Tue Apr 28, 2009 6:33 pm
paulfarre
paulfarre
sorry - nothing to do with the drivers
#2 by paulfarre
better i answer this one myself :oops:
Apparently my DiseqC switch went defective while i was upgrading the software. So Level=100% Quality=0 -- can be caused by no signal at all or maybe a shortcircuit ib the Diseq.
  • Thu Apr 30, 2009 4:15 pm
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 8:55 pm
