Is it possible to run DVB-T and DVB-S in parallel on hybrid?
1 post
paulfarre
paulfarre
Tue Apr 28, 2009 5:56 pm
#1 by paulfarre
Any way to enable DVB-S and DVB-T tuner parts simultaneously on Hauppauge WinTV HVR-4000?
  • Tue Apr 28, 2009 6:37 pm
1 post
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 8:55 pm
