Juergen wrote:Please post full details on that / an example feed.
Include FEC, eventually DVB-S2 or TurboFEC mode.
Also try to record and watch if the file size grows.
The subject may be pretty complex, and the reason for failure may be hidden behind each and every tiny little technical aspect...
Thank you for your reply. These are the feeds I tried yesterday:
Satellite: Thor 1W
Frequency: 11092
Polarisation: Vertical
FEC: 3/4
Symbole rate: 6111
Type: 4:2:2 non-HD
Satellite: Eutelsat 10E
Frequency: 11015
Polarisation: Horisontal
FEC: 3/4
Symbole rate: 21600
Type: 4:2:0 DVB-S2
(football French league Bordeaux vs Sochaux)
Satellite: Thor 1W
Frequency: 11469
FEC 3/4
Symbole rate: 20000
Type: 4:2:2 DVB-S2
(IIHF World Championship 2009)
The first frequency mentioned worked but it was a non-HD broadcast. I have got Prog DVB Pro (latest version 606) to display Luxe TV HD at 9E, 11804 V 27500. It shares the bandwith though with another HD channel plus 3 standard tvchannels so the bandwith allocated to Luxe TV is much less than the feeds I tried.
As mentioned in earlier posts, when I type in the channel settings in search mode I only get signal, no quality and thus the program does not find the channel. I tried various codecs, no difference. I even tried blind search just around the frequency I wanted to get but nothing came up.
I might add I have LifeView Trio card (DVB-S, DVB-T & DVB-C). It is BDA compliant though. I have configured only DVB-S in Prog DVB Pro as it is my primary interest.
It might be difficult for you to reproduce this problem but if you are in Europe then please try get the hockey feed (usually 4pm or 8pm CET). They usually stay on Thor on mentioned frequency. Or try any other HDTV feed that you might find with high symbole rate.
I like the Prog DVB Pro, its look and features and if I just get this HDTV feed thing work then I'll be happy to purchase a license and become registered user.
