progdvb crashes
hello
The last view versions of progdvb often crach when i try to close the application. While installing the program it also has problems with detecting dba devices (Pinnacle PCTV 450e). Also there is no picture or sound on any channel.
When i select settings > diseqc and providers and i make any selection and i click the ok button nothing happens (wheter i click 100 times the ok button the diseqc screen is still on top)
When i try to close the progdvb it crashes and show this message
at ()
at ..()
at ProgDvbNet.MainForm.(Object , FormClosedEventArgs )
at System.Windows.Forms.Form.OnFormClosed(FormClosedEventArgs e)
at IPDev.Skins.SkinForm.OnFormClosed(FormClosedEventArgs e)
at System.Windows.Forms.Form.WmClose(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at IPDev.Skins.Docking.DockForm.WndProc(Message& m)
at IPDev.Skins.SkinForm.WndProc(Message& m)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
CodeBase: file:///E:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
ProgDvbNet
Assembly Version: 6.6.1.0
Win32 Version: 6.06.1
CodeBase: file:///E:/Program%20Files/ProgDVB/ProgDvbNet.exe
EngineApiWrapper
Assembly Version: 1.2.9.0
Win32 Version:
CodeBase: file:///E:/Program%20Files/ProgDVB/EngineApiWrapper.DLL
msvcm80
Assembly Version: 8.0.50727.3053
Win32 Version: 8.00.50727.3053
CodeBase: file:///E:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3053_x-ww_b80fa8ca/msvcm80.dll
CodeBase: file:///E:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///E:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///E:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
ProgDvbNet.bc
Assembly Version: 1.0.2.0
Win32 Version: 1.0.2.0
CodeBase: file:///E:/Program%20Files/ProgDVB/ProgDvbNet.bc.DLL
IPDev.Skins
Assembly Version: 1.3.11.0
Win32 Version: 1.3.11.0
CodeBase: file:///E:/Program%20Files/ProgDVB/IPDev.Skins.DLL
ProgDvbNet.EPG
Assembly Version: 1.0.5.0
Win32 Version: 1.0.5.0
CodeBase: file:///E:/Program%20Files/ProgDVB/ProgDvbNet.EPG.DLL
ProgDvbNet.CC
Assembly Version: 1.0.4.0
Win32 Version: 1.0.4.0
CodeBase: file:///E:/Program%20Files/ProgDVB/ProgDvbNet.CC.DLL
System.Xml
CodeBase: file:///E:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
ProgDvbNet.Win
Assembly Version: 1.0.0.0
Win32 Version:
CodeBase: file:///E:/Program%20Files/ProgDVB/ProgDvbNet.Win.DLL
Accessibility
CodeBase: file:///E:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Design
CodeBase: file:///E:/WINDOWS/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll
System.Configuration
CodeBase: file:///E:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Drawing.Design
CodeBase: file:///E:/WINDOWS/assembly/GAC_MSIL/System.Drawing.Design/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.Design.dll
enabled.
For example:
<configuration>
</configuration>
P.S. the last correct working version for me is ProgDVB6.05Std. All newer version have the above problems.
P.S. Also i would like to ask wheter it is posible te add the network search function in the new versions of Progdvb.
today installed ProgDVB v6.06.2 i get still the above errors and it crashes.
(i suggest there is a problem with BDA devices)
When i install ProgDVB6.05Std it is ok, all newer versions have this problem
I had the same problem.
I installed the ver. 6.06.3 and after I sobstitued the BDA module with the ver. 6.03.1 and it works (no more craches).
Is it possible to change in the next ver. ?
Prog wrote:Do you have problem if copy bda.device from old version to new.
when i copy the old bda.device file it works correct.
is it posible that you put the old bda.device file to new relases of progdvb?
because now i always have to copy the old file when i install a new release of progdvb
Prog wrote:It is not easy fix without sample... try install last version of BDA.device and change mode in settings->device options.
which mode should i choose?
P.S. i tried to choose any mode of the list but after i click ok button it doesn't take any effect. then when i go again to settings>device options i see it is again set to (auto) unknown))
today installed ProgDVB v6.10
and it still has the above described errors
P.S. when i copy the bda.device file from progdvb 6.0.5 to v6.10 (replace the new one with the old one) it works fine
my tv card is Pinnacle PCTV 450e (bda device)
hi prog
i've instaled progdvb 6.11 and still got the same errors.
when i copy the old BDA.Device file in Modules directory it works fine
i've uploaded the working BDA.Device file hier:
http://rapidshare.com/files/257183991/BDA.Device.html
P.S. also got the same problems when i install progdvb on Vista 64 bit
but there i çan't copy the old BDA.Device file because it is not compatible. When i copy the old BDA.Device file in Modules directory and i start progdvb windows hangs then i have to reboot my computer
