Hi
I need to stream a full transport stream in multicast protocol.
I know that this option was removed from Prog Media Server because it overloads the network capacity. This is not my case because I have a GigaEthernet and very powerfull hardware.
Is it possible to purchase the last old version of "Prog Media Server for small networks" with TS streaming option ?
Thank you
I think it's very usefull the possibility to stream the full TS, in case you need to feed any other device.
You should have left the option in the ProgMediaServer and let the user decide if stream the full TS or only 1/few services
I already tested my DVB device in recording the full TS, using the "PID recorder" module and I see that it can.
Hi
Do u think it's possible to have an old version in which you can stream the full TS ?
Thank you very much
Thank you very much
