first of all, thanks for the great software.
I use the german channels and when I switch from ProSieben to Das Erste then I get a black screen and no audio.
If I switch back to another channel it works fine or when I go to preferences and select OK or restart ProgDVB then can I see 'Das Erste'.
This is only with the channel Das Erste.
All other functions work perfectly.
In another DVB-Program work the same Filter and Renderer without this problem. There can I switch the channels.
I read this also by other users in this forum.
Kind regards
Flansch
