Problems with KWORLD DVB-T PCI160-T2
1 post
Harkman
Harkman
Sat Jul 04, 2009 3:16 pm
#1 by Harkman
I have this card, with the sofwtware hypermedia center works properly, I have configure the card and found channels and stores in progdvb but when change the channel only see for a few seconds and then gets black screen and lost quality
change to another channel if I do the same.
I have a version 8.4.28.1 of the drivers of afa9015 bda
Anybody knows that it can be?
Thank you
  • Sat Jul 04, 2009 3:33 pm
1 post
Return to “Hardware”
Из России и Нидерладов файл доступен. Пользователи пока не жаловались.
Prog, Thu Jun 04, 2026 5:44 pm
Качается... Какие то региональные ограничения? Если и есть, то с вашей стороны. Попробуйте через tor-browser!
Mostwanted, Thu Jun 04, 2026 12:24 pm
Prog, Thu Jun 04, 2026 12:13 pm
https://files4.progdvb.com/progdvb/ProgDVB7.71.5x64.exe
Mostwanted, Thu Jun 04, 2026 10:29 am
  • It is currently Wed Jun 10, 2026 5:12 pm
