New user. Many many question for you......thanx
HI,
I'm a new user of progdvb, for me the best dvb player!!
I have a skystar usb 2 hd ci with the last release of progdvb shareware pro version, my pc have vista 32bit and I have a 125cm dish with Stab120 HH.
Now the questions:
1. For my configuration, on settings diseqc the correct choice is POSITIONER or CUSTOM? what is the difference?
2. I must select all sat position in LIST ?
3. How can select a satellite position without open a channel?
4. All sat position appear OK, but I have a problem with Eutelsat16°est
in this position the motor always go a little grade east and west and NEVER stop! Why? How can do?
5. Is possible scheduler two recordinds in two channel on two sat difference? example record a channel on hotbird from 14 to 15pm and then on astra from 16 to 17pm? How can make it?
6. Why on every start of the software the brightness setting reset?
7. If I open vplug plugin sometimes when close the software, I see a crash message. why?
8. I have downloaded here a module named DiSEqC by oNe3 ver1.753 and a plugin named DiSEqC 1.2 ver 0.6 by kva, but with theese the software make often a crash with some error in .dll or progdvbnet.exe
why?
thanxxxxxxxxxx for the answer!!!!!!!!!!
Don't use any plugins, until all basic functions work well.
How do you drive that motor, by DiSEqC or something else?
If it's DiSEqC, you need to set it up as a positioner, of course.
Should not need any extra plugin AFAIK.
If you wanted to make timer recordings from various birds, you have to consider, dish movement needs time. So the usual couple of seconds between station setting and record start on the internal scheduler won't be enough, manual editing required.
Anyway, we don't talk any decrypting plugin issues over here.
