    • Unanswered topics
    • Active topics
Problem with SkyStar Remote Control
Javidan
Javidan
Wed Jul 15, 2009 9:44 am
#1 by Javidan
When I press a key, ProgDVB thinks that I pressed it two times.
For example, it changes the channels two by two.
I've SkyStar USB2 HD CI, Vista SP2 x64
Any solution? :cry:
  • Thu Jul 30, 2009 5:00 pm
Try disable module in Settings->Controls
  • Thu Jul 30, 2009 5:06 pm
Установил мобильную ПрогТВ, удалил из папки два шрифта, скопировал свой файл шрифта - не работает. Шрифт в программе обы
kostan, Sat Nov 08, 2025 10:06 pm
If this is what you mean, yes i can send you the file, just tell me how, Thanks. I've sent the logs to the de
nikspk, Sat Nov 08, 2025 7:38 pm
Can you send me logs from "bad" and "good" version from same channel? You can install old version from msi and new
AndresMaxx, Sat Nov 08, 2025 5:48 pm
Can you send me logs from "bad" and "good" version from same channel? You can install old version from msi and new a
nikspk, Sat Nov 08, 2025 4:59 pm
  • It is currently Sun Nov 09, 2025 12:08 am
