Problem With SkyStar2
y85.fox
y85.fox
Sun Aug 16, 2009 8:23 pm
#1 by y85.fox
hi
i have skystar2 :D with new Driver
it's work Good with DVBViewer :lol:
But after install ProgDVB6.11.3Std
On Windows Xp
It's Good But With Green Secreen :?:
  • Sun Aug 16, 2009 9:18 pm
Then your video card too old. Try change Settings->Options->Video->Video render
  • Mon Aug 17, 2009 6:35 am
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 8:53 pm
