Hello!
Now this sounds very nice and useful.
But is there a place to get some info about?
What client, protocol and port to use?
How to set it up?
Thank you and keep up the good work.
Hi!
I'd also like to know how this module has to be set up.
It seems like a very useful feature to me...
Thanks in advance
Regards,
Andy
BTW does it work in the free version?
Thanks in advance
Regards,
Andy
yes it is installed and i can enter a username and a password.
and there is a check and a create button which show an error message.
what has to be configured? any port forwardings?
regards
regards
now after pressing create and check it says ok.
but i dont know how to view the channels on the client now.
thanks.
thanks.
ah ok thanks.
that's how it works.
i dont have a sat card installed at the moment.
i wanted to test that with internet tv channels.
as i dont get a channel list on the client side i suppose it only works with real satellite channels?
regards
andy
regards
andy
now i was able to test with sat channels.
i configured everything and on the client side after checking the credentials it says ok.
then i do a channel search. but nothing happens. not even a windows pops up. any ideas?
please help.
regards
please help.
regards
NAT (ports 10997&10998) for server if need.satluver wrote: then i do a channel search. but nothing happens. not even a windows pops up. any ideas?
ok i'll try that!Akad wrote:NAT (ports 10997&10998) for server if need.satluver wrote: then i do a channel search. but nothing happens. not even a windows pops up. any ideas?
tcp and udp?
#15
tcp only. 10997 for windows media streaming and 10998 for command connection (switch channel, channel list request, etc).satluver wrote:ok i'll try that!Akad wrote:NAT (ports 10997&10998) for server if need.satluver wrote: then i do a channel search. but nothing happens. not even a windows pops up. any ideas?
tcp and udp?
