the list of which cards work with windows 7
1 post
batzzz19
batzzz19
Thu May 15, 2008 4:31 am
#1 by batzzz19
does anyone have a list of which cards
work with windows 7
i've heard that happauge nova-s does
and the hd one does too but don't want to buy
unless im sure
im using windows 7 build 7600
  • Sat Sep 05, 2009 6:33 am
1 post
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 8:52 pm
