First of all thank you for this great program that I use from so many years.
Recently, I decided to buy the Pro version for watching pay TV (HD channels) but I have an annoying problem.
My system :
Vista x64 SP2 + Skystar HD 2 CI + ProgDVB Pro 6.21 + Cryptoworks module and smartcard for Digiturk pay TV.
First problem :
My problem presents like this, when I open ProgDVB for the first time, the last channel I viewed last time appears normally but when I select another channel even on the same transporder nothing appears, no image and no sound (the signal is ok).
If I close ProgDVB and re-open it, the last channel I selected and that wich didn't appear, appears like magic
That concern only crypted channels.
So for changing channel I need to quit and re-open ProgDVB each time.
Second problem :
When a record a crypted channel, I can play it after on all the media players, but when I try to convert the .ts file in AutoGK or another converting program, it says me that the file has no video stream ???
I remember again that these problems concern only crypted channels and they appears only in ProgDVB.
Because with the software who comes with the Skystar (DVBViewer) I have none of this problems, I can zap normally into channels and and can convert my recorded files.
I really want to use ProgDVB cos I like it and I paid it ...
Thank you for reading me and for a fast answer I hope.
NB : sorry if I made faults, english is not my primary language.
