hello ,
installed today Progdvb 6.21.1 Version
i use Time shift buffer saved on a file into root
while watching is ok but if you want to come back to old scene via Time shift buffer you will loose Audio of this channel only video work
Thanks Prog
ok i did some change in audio & video setting
switching between cyberlink , Ulead , Nero & Realtek
now is fine
now is fine
@JohnJohn wrote:ok i did some change in audio & video setting
now is fine
i have the same problem.
what exactly have you do changed?
thanks
sorry for been latetorr8 wrote:@JohnJohn wrote:ok i did some change in audio & video setting
now is fine
thanks
why i did changed is on settings = Options= Audio
i Changed Audio Render with Realtek mine & Also Render AC3
and MPEG with Ulead one
try to combine those & you will sort this out
remember this bug been found on newer version
