Hauppauge Win-TV CI USB
    • ProgServer
    • ProgMusic
    • ProgFinder
    • Elecard ViCont
  • Privacy Policy
umbyh
umbyh
Mon Nov 23, 2009 1:53 pm
#1 by umbyh
Hello everyone,
in my HTPC I installed a Hauppauge WinTV-HVR-4000 and WinTV-CI, the latter equipped with Samsung Card for DVB-T.
My problem is that I can not see the WinTV-CI in the menu of CI.
Can you help?
Thanks
  • Mon Nov 23, 2009 2:13 pm
bvb09
bvb09
Tue Jan 03, 2012 1:00 am
Re: Hauppauge Win-TV CI USB
#2 by bvb09
hello
i have same problem
Hauppauge WinTV-HVR-4000 and WinTV-CI, please how can use my WinTV-CI in latest progdvb
please help
thx :)
  • Tue Jan 03, 2012 1:02 am
#3 by Prog
Current version ProgDVB not support Hauppauge CI device.
  • Wed Jan 04, 2012 1:14 pm
Return to “Hardware”
User avatar
  • It is currently Fri Oct 30, 2026 3:48 am
