    • Unanswered topics
    • Active topics
dvb-t terratec usb
1 post
antipro
antipro
Wed Nov 25, 2009 8:09 am
dvb-t terratec usb
#1 by antipro
hi, i need some help with my receiver.
it's an usb dvb-t only terratec adapter.
when i search for channels i can't find anything.
i'm using the 64bit version under vista
  • Wed Nov 25, 2009 8:15 am
1 post
Пришлите логи. Я сейчас как раз отлаживаю эту функцию. На разных форматах бывают разные сложности. Начните с простых :)
Prog, Sun Dec 14, 2025 7:21 pm
Re: add progdvb pro on anothe…
You can enter same registration data to activation on second device. But for the third device, you will need a new licen
Prog, Sun Dec 14, 2025 7:19 pm
add progdvb pro on another la…
i have prog pro . how can i add it on another laptop? i have already downloaded it but it is on the trail version.
prop, Sun Dec 14, 2025 3:39 pm
User avatar
  • It is currently Sun Dec 14, 2025 8:39 pm
