    • Unanswered topics
    • Active topics
ProgDVB 6 Pro and Windows 7 x64
1 post
Javidan
Javidan
Wed Jul 15, 2009 9:44 am
#1 by Javidan
Everytime I turn on my laptop and open it, it crashes.
So I have to close it from Task Manager and re-open it and it'll work well :?
  • Tue Dec 08, 2009 9:48 pm
1 post
Установил мобильную ПрогТВ, удалил из папки два шрифта, скопировал свой файл шрифта - не работает. Шрифт в программе обы
kostan, Sat Nov 08, 2025 10:06 pm
If this is what you mean, yes i can send you the file, just tell me how, Thanks. I've sent the logs to the de
nikspk, Sat Nov 08, 2025 7:38 pm
Can you send me logs from "bad" and "good" version from same channel? You can install old version from msi and new
AndresMaxx, Sat Nov 08, 2025 5:48 pm
Can you send me logs from "bad" and "good" version from same channel? You can install old version from msi and new a
nikspk, Sat Nov 08, 2025 4:59 pm
  • It is currently Sun Nov 09, 2025 2:18 am
