    • Unanswered topics
    • Active topics
How to expand the list of channel ?
John
John
Mon Sep 28, 2009 5:28 pm
#1 by John
Hello ,
i'am tired of expand each tp alone
is there a way to see all channel expanded order by transpordeur ?
Thanks
  • Fri Dec 25, 2009 4:43 pm
In properties of channel list?
  • Fri Dec 25, 2009 7:00 pm
Re: Lib VLC Engine Pop Up
In prerelease fix of Engine mode. But this is not last update...
Prog, Tue Aug 05, 2025 9:22 pm
Re: The sound of voices in mo…
Hello. Do you use libvlc mode? You can try ProgDVB Engine also. Options->Playback->VOD = ProgDVB Engine. + You can try s
Prog, Tue Aug 05, 2025 5:27 pm
The sound of voices in movies.
Hello, I bought the ProgTV version and I have a problem, when I am in my movies section and I play one, the sound of the
ThePoGoBoY, Tue Aug 05, 2025 12:36 pm
Re: проблемма со звуком
А что за провайдер такой? Более чем странный подход. Скорее 25 лет как ТВ занимаюсь, в первый раз вижу. У меня не о
kostan, Mon Aug 04, 2025 3:13 pm
  • It is currently Wed Aug 06, 2025 6:25 am
