    • Unanswered topics
    • Active topics
How to remove LNB-Tab in channellist
Sepp
Sepp
Fri Dec 22, 2006 10:46 am
#1 by Sepp
hi,
I've got that annoying empty LNB-Tab in my channellist.
How can i remove it?
~sepp
  • Sat Dec 23, 2006 1:14 pm
SiLencer
SiLencer
Fri Nov 03, 2006 12:10 pm
#2 by SiLencer
switch on it...channel list menü ->delete...
  • Sat Dec 23, 2006 1:22 pm
Sepp
Sepp
#3 by Sepp
great work!
thank u!
  • Sat Dec 23, 2006 1:26 pm
Re: IPTV channel list issues
1. I changed the leading character to * and it sorts properly now. It seems you are removing leading . characters from t
noremorse57, Sat Sep 06, 2025 2:08 pm
Re: first response feedback
Thanks for feedback. It is more convenient to respond to text as in a video. 1. I am not can repeat first problem with
Prog, Fri Sep 05, 2025 4:21 pm
Hello peeps. First off, I'm glad to have found this IPTV software, windows generally has very poor selection, not like
fredphoesh, Thu Sep 04, 2025 4:24 pm
Re: Pop Up Issue
Reset is greyed out. For the record, I had been using the latest version since release with no issues until this morning
gaztaylor, Thu Sep 04, 2025 3:38 pm
  • It is currently Sat Sep 06, 2025 4:11 pm
