    • Unanswered topics
    • Active topics
Progdvb Youtube?
fernanto
fernanto
Fri Jan 01, 2010 7:53 pm
Progdvb Youtube?
#1 by fernanto
I can´t see youtube videos with Prodvb 6.30.01.
I see all the channels and Internet TV/Radio .
Can you help me?
Thanks
  • Fri Jan 01, 2010 8:02 pm
Do you try search of clip?
  • Fri Jan 01, 2010 8:13 pm
fernanto
fernanto
#3 by fernanto
How can I do that?
  • Fri Jan 01, 2010 8:28 pm
#4 by Prog
For example if select YouTube list, you can use text line list over the list.
Or use menu of this text line.
  • Fri Jan 01, 2010 8:34 pm
fernanto
fernanto
#5 by fernanto
Infortunly I csn't see a Youtubr list...
  • Fri Jan 01, 2010 8:44 pm
#6 by Prog
OK. Do you see text line for search?
Use menu over arrow downwards.
  • Fri Jan 01, 2010 8:59 pm
fernanto
fernanto
#7 by fernanto
Yes I can see a blank line search, but there are no list...
What must I write there?
  • Fri Jan 01, 2010 9:05 pm
#8 by Prog
For example click on arrow in right of this line.
  • Fri Jan 01, 2010 9:53 pm
fernanto
fernanto
#9 by fernanto
I've uninstalled the program and I've reinstalled. Now I can see a list of Youtube movies!
Thanks a lot!!!
  • Fri Jan 01, 2010 9:57 pm
Re: Lib VLC Engine Pop Up
What channel working with VLC but not working in Engine mode?
Prog, Wed Aug 06, 2025 9:24 pm
What you mean " no catetegories division " ? Is it music list?
Prog, Wed Aug 06, 2025 9:23 pm
I've just tested ProgDVB7.67.4b.x64 Pre Release with progDVB engine and seems working now, starting directly in HD or FH
macumbero, Wed Aug 06, 2025 9:01 pm
In prerelease fix of Engine mode. But this is not last update...
Prog, Tue Aug 05, 2025 9:22 pm
  • It is currently Thu Aug 07, 2025 1:00 am
