Standar vs Professional
I've installed the "ProgDVB for Windows 2000/XP/Vista/Win7" Standard
version and it works fine with the plugin Flyccam.
When I use the ProgDVB x32 Professional for 2000/XP/Vista/Win7 I can't access this Plugin.
I´ve tryed to put the Flyccam files on the root and also on the Plugin's directory but the result is the same...
Can you hel me please?
Re: Standar vs Professional
fernanto wrote:I've installed the "ProgDVB for Windows 2000/XP/Vista/Win7" Standard
i dont think there is some problem with plugin
as you may know prog dont like talking about plugin & hack & so
so google hadu dvb that will solve ur problem
& yes Pro Version is so far better & got HD channel...
