    • Unanswered topics
    • Active topics
Play a "recording" file... and continue recording.
1 post
olgos762
olgos762
Thu Dec 03, 2009 9:41 am
#1 by olgos762
Hi all,
is there a way to play a "recording" file and continue recording?
Best Regards..
  • Thu Jan 21, 2010 9:41 am
1 post
Re: Error with scheduler in P…
Please describe the steps. Do you click “mark for record” and ProgDVB crashes? Or do you need to create 2-3 recording
John90, Sun Nov 09, 2025 9:36 am
Свой файл с тем же именем что и старые? Нет, свой файл с тем именем, кое у него было. Ааа... понял. Нужно положить
kostan, Sun Nov 09, 2025 8:36 am
Also check black background of video. For example, if the application window is narrow but the channel is 4:3. What are
Prog, Sun Nov 09, 2025 7:09 am
In logs total same mode... btw, do you have color changes in ProgTV interface? You can select black color scheme on both
Prog, Sun Nov 09, 2025 6:53 am
  • It is currently Sun Nov 09, 2025 10:55 am
