Hi folks, I would like to create some skins and try to edit new ones! How do I proceed? theres a program, and option? any hint?
If I made a skin for the free version it will works on the full version too?
Tks
Damm is it easy! but needs a litle time.
First we see how to change buttons....
In the ProgDvb directory there´s a file called SkinEditor.exe
1. run it;
2. go to "file - open skin" and choose one...
3. it will load
4. create a directory called "skins test" wherever you want
5. click on "tools" export to folder and choose the folder your created
Now the buttons and other graphics will be there !
Open the file you wanna change with your pref editor like gimp, paintnet, even mspaint
- modify it ! and save it
In the skin editor click the right menus, and browse the itens, so click on "..." and browse and open the file you changed. Click on "Save as" to create a "new one" skin and don´t screw the original.
1. run it;
3. it will load
