Hello,
ProgDVB 6.34.3, Win 7 64
Hardware: Technotrend TT-connect S2-3650 CI, X-Fi Extreme
Problem: i get no sound when AC3 is enabled - as well as SD and HD. I tried all possible adjustments - no success. "Normal" sound works fine.
In the screenshot you can see the options in adjustment:
http://www.pictureupload.de/originals/6 ... vb_ac3.jpg
Any hints?
Many thanks in advance and BR!
Sorry, i don't know where i could choose any codec - what do you mean?
FYI: with technotrend viewer an technotrend mediacenter AC3 works fine!
