Hi! I also use the the Terratec Cinergy S USB Hardware Box. ProgDVB starts and I can select the device (Terratec USB-S). But between 10 oder 20 seconds later ProgDVB crashes with an error message.
I deselected all modules and deleted the Teletext plugin (also Error-messages with the Teletext plug).
The card works brilliant with the Terratec Homecinema-Software but I have problems with ProgDVB!
But there's no chance to fix the problem:
- Does anybody have some experiences with the Terratec Hardware?
- Will it be supported in future?
- Is there an other application that supports the Terratec Cinergy S USB-device?
Greetz from Austria
Helmut
Why don't you post the error message you've mentioned?
At least the important / helpful parts...
After many hours of trying and patching I fixed the problem. Finally I found the following patch windowsxp-kb896626-v2-x86-deu - applied it and - taraaaaaaaa! It works great - no crashes and no error messages.
Okay - Here are my settings with Terratec Cinergy S USB under WinXP Home SP2:
Device: (BDA) TerraTec_Tuningspace_DVBS
ProgDVB: Version 4.81.1[1.20/Standart.Edition]
Greetz
Helmut
