There is no such problem with another hd channel Servus TV HD works perfect for me. What's the problem?
Pls help
I use windows 7 x64
I'm not sure which video codecs I use. What i do know its progdvb pro 21 day trial.Cjcr wrote:What video codecs are using?
If using the ATI codec, forget it, you have problems with DVB-Stream ...
(In H.264 format)
but how do i start with Debug key?Prog wrote:Try start with /Debug key and look Debug->Filter manager->dropped packet?
It's easy, go to Options, Video -> Codecs, and here you will find that codec you're using.ronart wrote:I'm not sure which video codecs I use. What i do know its progdvb pro 21 day trial.Cjcr wrote:What video codecs are using?
(In H.264 format)
as far as i see Servus TV HD does use H.264
ps. I use Prof 7301 PCI card
Cjcr wrote:It's easy, go to Options, Video -> Codecs, and here you will find that codec you're using.ronart wrote:I'm not sure which video codecs I use. What i do know its progdvb pro 21 day trial.Cjcr wrote:What video codecs are using?
(In H.264 format)
Did not change. Still disturbing scrambleCjcr wrote:In ProgDVB shortcut, Properties, at the end of the path where start, add this: "C:/Program files/ProgDVB/progdvbnet.exe" /Debug
I did copy and paste "C:/Program files/ProgDVB/progdvbnet.exe" /DebugCjcr wrote:add 1 space ("C:/Program files/ProgDVB/Progdvbnet.exe"SPACE\Debug
About codecs..
Change H.264/AVC for other codec, like Cyberlink PowerDVB, Arcsoft, NVIDIA, DivX H.264, etc, and try again....
grettings.
