    • Unanswered topics
    • Active topics
ProgDVB Pro 64Bit: Different Hardware ID
Javidan
Javidan
Wed Jul 15, 2009 9:44 am
#1 by Javidan
I tried to install ProgDVB Pro x64, but got different Hardware ID than x86 version :?
Only two fields :?
  • Sat Jun 19, 2010 8:43 am
Re: ProgDVB Pro 64Bit: Different Hardware ID
You can make key for x64 over reg2.progdvb.com -> Update
  • Sat Jun 19, 2010 2:36 pm
Установил мобильную ПрогТВ, удалил из папки два шрифта, скопировал свой файл шрифта - не работает. Шрифт в программе обы
kostan, Sat Nov 08, 2025 10:06 pm
If this is what you mean, yes i can send you the file, just tell me how, Thanks. I've sent the logs to the de
nikspk, Sat Nov 08, 2025 7:38 pm
Can you send me logs from "bad" and "good" version from same channel? You can install old version from msi and new
AndresMaxx, Sat Nov 08, 2025 5:48 pm
Can you send me logs from "bad" and "good" version from same channel? You can install old version from msi and new a
nikspk, Sat Nov 08, 2025 4:59 pm
  • It is currently Sun Nov 09, 2025 6:47 am
