    • Unanswered topics
    • Active topics
Update Transponders File
MoHaMeDYoUsRi
MoHaMeDYoUsRi
Fri Nov 24, 2006 8:39 am
#1 by MoHaMeDYoUsRi
Hi all ,
How can i update my transponders files or do a network scan to get all channels available at the satellite [ NileSat as example ]
thanks a lot and have a nice time
Tevii S420 - Windows 7 64-bit
  • Sun Jun 20, 2010 9:11 am
Re: Update Transponders File
ProgDVB use network scanner every time (exclude scan transponder)
  • Sun Jun 20, 2010 9:59 am
MoHaMeDYoUsRi
MoHaMeDYoUsRi
#3 by MoHaMeDYoUsRi
Prog wrote:ProgDVB use network scanner every time (exclude scan transponder)
So when i open channel list-->channel search-->My sat card-->Nilesat(as example) those steps include network search or there any other steps i have to do ??
  • Sun Jun 20, 2010 10:05 am
#4 by Prog
This mode include network search.
  • Sun Jun 20, 2010 10:52 am
MoHaMeDYoUsRi
MoHaMeDYoUsRi
#5 by MoHaMeDYoUsRi
Prog wrote:This mode include network search.
Thanks a lot for your help
  • Sun Jun 20, 2010 11:13 am
Re: IPTV channel list issues
leading . characters causes issues and are stripped in the channel list leading * characters works ok
noremorse57, Thu Sep 11, 2025 2:52 pm
Re: ProgTV WinUI3
Это поверх старой версии ставилось? Проверю
Prog, Thu Sep 11, 2025 4:43 am
Re: ProgTV WinUI3
У вас какой-то глюк с таймшифтом в последней версии. Смотрите, сколько у меня мегабайт выставлено. И это ставил не я. Эт
kostan, Thu Sep 11, 2025 2:26 am
Re: ProgTV 3.8.3 - Trail Peri…
The Name, Email, and Key fields are blank. There are numbers in the HID field. Do you want them? I have installed 3.8.
MG317, Wed Sep 10, 2025 3:11 pm
  • It is currently Thu Sep 18, 2025 3:04 am
