Re: ProgDVB 6.43.02 , Skystar2 HD and SG2100 rotor
OK I now have another new Skystar HD 2 card and it's still the same as the old one, no rotor movement. I have tried disconnecting the LNB to lower the current drawn from the card and still no movement. I know it's not the rotor as it works every time with my old Skystar 1 card. Anybody have any ideas?
#15
I have two brand new Skystar HD 2 cards one came direct from Germany and the other from a seller in the UK, both of which don't work with rotors. I'm not sure if the new cards are a different revision but they have a few components missing when comparing them to pictures of the same card off the internet. The choke L4 is missing and a few other bits around the LNBP21 supply and control IC.
Anyway I will give TechniSat a ring and see if they can give any explanation why the rotor may not be working.
