THE SOFTWARE FREEZES (STOP RESPONDING) ON 'CHANNEL SEARCH'
I live in Lagos, Nigeria and uses HP DV4 Pavilion running Windows7.
I have set up My LIGHTWAVE USB DVB-S Box (Advanced USB2.0 DVB-S TV BOX) with the driver supplied and installed the PROGDVB software but i have a problem:
1. When I install PRODVB in Window7 32bit, the software freezes (stop responding) few seconds after starting 'channel search'.
I also could not install my box in Window7 64bit since the driver supplied with my box does not support 64bit
Re: THE SOFTWARE FREEZES (STOP RESPONDING) ON 'CHANNEL SEARC
owokasib wrote:I live in Lagos, Nigeria and uses HP DV4 Pavilion running Windows7.
usually it may be bad driver not work with some transponder. try ask card makers.
