    • Unanswered topics
    • Active topics
Is 64bit activation code valid for 32bit also?
bou
bou
Wed Nov 08, 2006 11:26 pm
Athens, Greece
#1 by bou
Can I use my 64bit registration activation code to use also 32bit on same machine and operating system? :?: :(
  • Wed Jul 28, 2010 6:06 pm
Re: Is 64bit activation code valid for 32bit also?
Yes. You can use both version (x32 and x64). But you should make new key over reg2.progdvb.com -> Update
  • Wed Jul 28, 2010 6:25 pm
bou
bou
Athens, Greece
#3 by bou
Thanks alot!
  • Wed Jul 28, 2010 6:33 pm
Re: ProgTV WinUI3
Поправлю
Prog, Mon Aug 18, 2025 6:19 am
Re: ProgTV WinUI3
Сортировка по номерам после сортировки по номерам не работает. Например, я рассортировал по номерам каналы в листе. Зате
kostan, Mon Aug 18, 2025 4:40 am
Re: 0xc0000005 and 0xc0000374…
Hi, I installed the latest version 7.67.05 and no more crash !! The issue is finally solved. Thank you !
quack, Sat Aug 16, 2025 1:23 pm
Re: archive is not working
What source of TV you use? Check "API" settings if you use m3u list.
Prog, Fri Aug 15, 2025 6:47 am
  • It is currently Mon Aug 18, 2025 10:44 pm
