Hello again,
Is there a way to do a full scan without using NIT? I've turned off what might be the relevant setting(s) but still my scans detect new transponders.
Presumably this shouldn't happen, because I am first using the transponder list program from fastsatfinder.com to load up to date transponder details. I assume it is correct and loads an accurate all.list.
Generally, I am trying to debug why no two scans of the same satellite seem able to result in the same channels added or lost. Even when the second scan is run immediately after the first one.
Thanks,
Lee
UK
Turn off NIT scanning ?
#1Hauppauge WinTV-NOVA-HD-S2 (PCI). Fixed dishes on Astra1, Astra2, Hotbird and Hispasat. DiSEqC 1.0. Windows 7 Home Premium 32 bit. I also have a WinTV-NOVA-S-USB2.
