Loudspeakers are off while scheduled recording
While scheduled recordings the loudspeakers are off.
This effects only while scheduled recordings.
In case of spontaneity recordings (Service/Start recording) the loudspeakers are on and it's possible to monitor the recordings.
I use momentary the free 32-bit version 6.46.05
Thanks
Carlos
DVB-Card:
WinTV Nexus-S release 2.2
alias
TechnoTrend TT-PCline premium S
T-premium® S-2300
Galaxis DVB PC-Sat-Card
Technisat SkyStar 1
Driver:
TT-premium release 1.7.0.6 (21.04.2009)
WDM TV-card drivers without virtual network adapter
(Windows XP/Vista/WIN7 32-bit)
(not the so called "KS" release for PCIe-Systems!)
driver contains only three files:
saa7146n.cat 30.04.2010
Saa7146n.inf 30.04.2010
Saa7146n.sys 06.09.2004
own experience:
Win XP Professional SP3 as working system AND Win Seven x32 Enterprise SP1 as test system
System:
CPU: DualCore Intel Core 2 Duo E6750, 2666 MHz
Motherboard Chipset: Intel Bearlake P35 (PCIe-System!)
DVB-Card-Firmware:
Boot (=Firmware of DVB-card)
Source: TT software and driver package rel. 2.19h 24.04.2007
Dpram 28.02.2005
Root 28.02.2005
Boot_up.axf 06.06.2001
ProgDVB use older firmware in the moment
Usage of ProgDVB:
Currently only in hardware mode, time shift, internet or streaming functions disabled
Re: Loudspeakers are off while scheduled recording
Hello Prog, thanks for your reply.
No, I have not set the "mute option", only the first option "change channel".
But this was absolutely a random!
Why random?
I cant recognized this opportunity.
In the English GUI stand on left side:
"File name"
When a scheduled a record, I don’t understand what this mean!
I speculate "File name" is here a wrong term. I think "options"(In German Optionen) will be better and more clearly.
In my normal German GUI
File name =Dateiname, this is a correct translation.
The other options in German GUI are not translated.
If you want, here is my translation:
Change channel an mute/Kanal wechseln und stumm schalten
Open channel in new window/Kanal in neuem Fenster öffnen. You can write for ö also oe (öffnen or oeffnen).
Open channel in Background/Kanal minimiert wechseln
But caution, I don't know exactly what's happen in ProgDVB when choosing the last two options in the pull down menu.
For this reason the translation will not be perfect!
These two options are additional options of the shareware version. In the moment I use the freeware version!
Regards
Carlos
DVB-Card:
alias
T-premium® S-2300
Technisat SkyStar 1
Driver:
own experience:
System:
DVB-Card-Firmware:
Dpram 28.02.2005
Root 28.02.2005
Usage of ProgDVB:
A little correction of myself:
options/Optionen not File name/Dateiname
1) Change channel/Kanal wechseln
2) Change channel an mute/Kanal wechseln und stumm schalten
3) Open channel in new window/Kanal in neuem Fenster öffnen(oeffnen)
4) Open channel in Background/Kanal minimiert wechseln
Carlos
DVB-Card:
alias
T-premium® S-2300
Technisat SkyStar 1
Driver:
own experience:
System:
DVB-Card-Firmware:
Dpram 28.02.2005
Root 28.02.2005
Usage of ProgDVB:
In version ProgDVB6.48.2Std I have seen the changes (English text, German translation).
When I make a scheduled recording, I can only use the first option
"Change channel"
It’s the same, effect. The loudspeakers are still mute while ProgDVB make a recording.
If I try to use one of the other options
Change Channel and mute
Open channel in background
appear a Window with the message
"PIP is supported only in ProgDVB Professional"
I think, these options are not corresponded with PIP (Picture in Picture), this is absolute different function! Or is this a mistaken idea?
Regards
Carlos
DVB-Card:
alias
T-premium® S-2300
Technisat SkyStar 1
Driver:
own experience:
System:
DVB-Card-Firmware:
Dpram 28.02.2005
Root 28.02.2005
Usage of ProgDVB:
