I have Technisat Skystar HD 2 and CI-Slot for dis card.
I´ve registered ProgDVB x64 and x32 running on Win7 Pro x64.
Both are Version 6.48.01.
In CI-Slot works a Technisat Cryptoworks CAM with ORF-Card.
On Settings - Device-Options-Additional API is Azurewave-Twinhan and in Settings-Options-Other is Enable-CAM-Interface activated and if i click Settings-CamInterface there appears a Window "TSD Crypt CW" and the Menu of the CAM.
If i click on ORF 2 HD, the comes no picture, with DVBViewer TE2 i get picture on this channel.
What should i do to make CAM-Interface exactly working ?
Re: ProgDVB 6.48.01 both x32 and x64 no picture with ORF-Car
#2Nobody has a tip ?
Could Prog please say something to this post ?
ProgDVB 6.48.4
#3I have some reports about this problem from other users. And plane check in near days.
#5Super, ORF-Card runs now, but when i switch to AC3-Sound in encrypted Broadcast-Stations (ORF), Screen goes black until i switch back to Stereo.
Please make AC3-Sound working on encrypted stations !
ProgDVB 6.48.4
#6Do you use ac3filter?
Also try change channel again after switch audio stream.
#7Yes Sir, I use AC3Filter, unscrambled Channels work with AC3, only scrambled Channels go to Darkscreen, when switched to AC3-Stream.
And i do change Channel after switching to AC3-Stream.
ProgDVB 6.48.4
