Does motor work with any specific card?
muven
muven
Sun Dec 16, 2007 9:44 pm
Bergen Norway
#1 by muven
I'd like to know if a motor upset with ProgDVB Pro /DiseqC motor or via posioner. What card is most "clever" in this upset ?
thanks
TT
  • Mon Oct 18, 2010 8:54 am
Paderman
Paderman
Mon Dec 17, 2012 4:08 pm
Re: Does motor work with any specific card?
#2 by Paderman
SkyStar 2 eXpress HD doesn't support motor :(
Regards/Gruß
Paderman
  • Wed Dec 19, 2012 9:57 pm
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 9:47 am
