    • Unanswered topics
    • Active topics
Skystar USB HD and remote control
ace_pt
ace_pt
Thu Nov 11, 2010 11:41 pm
#1 by ace_pt
Hi all i need some help to configure the remote control on progdvd on my skystar USB HD
  • Thu Nov 11, 2010 11:44 pm
sky star 2
sky star 2
Tue Nov 30, 2010 9:11 pm
Re: Skystar USB HD and remote control
#2 by sky star 2
ace_pt wrote:Hi all i need some help to configure the remote control on progdvd on my skystar USB HD
viewtopic.php?f=3&t=5531
  • Tue Nov 30, 2010 11:17 pm
riki
riki
Mon Dec 27, 2010 6:35 am
#3 by riki
Yes I have got all the solution so please tell me your trouble so that I can pick you the correct solution and make it work for you. You are using a HD usb Prog DVB right. Then it requires a bit hardware change in your system. So please specify what problem exactly you are experiencing.
hhgregg
  • Mon Dec 27, 2010 7:06 am
Return to “Hardware”
I am not download this list. Really huge list. I change your password in list and use it as crash test:) ProgDVB very sl
Prog, Mon Dec 15, 2025 7:39 am
А лучше ссылку на канал. mkv/mp4 неудобные форматы для записи и всегда будут отличаться тем, что работать хуже чем TS. П
Prog, Mon Dec 15, 2025 7:10 am
running raseberry tv on progd…
i have it running on 2 other windows devices with no problems . i bought a new subscription for a third device and it!s
prop, Sun Dec 14, 2025 11:59 pm
Пришлите логи. Я сейчас как раз отлаживаю эту функцию. На разных форматах бывают разные сложности. Начните с простых :)
Prog, Sun Dec 14, 2025 7:21 pm
  • It is currently Mon Dec 15, 2025 10:32 am
