    • Unanswered topics
    • Active topics
How can I use ProgDVB in the local network
  • 1
  • 2
SubZero
SubZero
Sat Nov 27, 2010 4:02 pm
#1 by SubZero
Hi everyone
I have a network of local Internet
and Azurewave TV Card
I want to use the ProgDVB
and use the card of all network computers
With the possibility of changing the channel
What is the requirements?
and what is the settings i need to ?
Thank you ..
sorry my for my bad language :)
  • Sun Nov 28, 2010 12:20 pm
SiLencer
SiLencer
Fri Nov 03, 2006 12:10 pm
Re: How can I use ProgDVB in the local network
#2 by SiLencer
http://download.progdvb.com/manuals/pms.zip
  • Sun Nov 28, 2010 12:37 pm
SubZero
SubZero
#3 by SubZero
SiLencer wrote:http://download.progdvb.com/manuals/pms.zip
I need something more specific :(
  • Sun Nov 28, 2010 1:16 pm
SubZero
SubZero
#4 by SubZero
no body can help me ??
:cry: :( :|
  • Mon Nov 29, 2010 12:35 am
#5 by Prog
But what problem you have? Do you read manual?
  • Mon Nov 29, 2010 7:16 am
SubZero
SubZero
#6 by SubZero
Prog wrote:But what problem you have? Do you read manual?
yes i read manual but I did not understand it :cry:
i need what exactly should do for use ProgDVB in every computer in my network
Thanks for the helping ...
  • Mon Nov 29, 2010 8:14 pm
#7 by Prog
You should read manual and setup server and clients.
  • Tue Nov 30, 2010 8:27 am
SubZero
SubZero
#8 by SubZero
Prog wrote:You should read manual and setup server and clients.
Already done ..
but the clients cant change the channel :cry:
if he try to change it the ProgDVB stop working in the server and clients !!
i use Prog Media Client
  • Tue Nov 30, 2010 11:12 am
#9 by Prog
Try remove all files in channels directory, and use scan function for receive list.
  • Tue Nov 30, 2010 11:16 am
SubZero
SubZero
#10 by SubZero
Prog wrote:Try remove all files in channels directory, and use scan function for receive list.
i use scan and i receive all channel list ..!!
the channels work fine in my PC and in Client PC too ..
but the client cant change the channel ??
  • Tue Nov 30, 2010 4:39 pm
SubZero
SubZero
#11 by SubZero
Please Help me Admin :roll:
  • Tue Nov 30, 2010 9:32 pm
#12 by Prog
That should work. I am not have idea. try clear and rescan list on server too.
Also check firewall settings and password on client/server.
  • Wed Dec 01, 2010 8:22 am
SubZero
SubZero
#13 by SubZero
Prog wrote:That should work. I am not have idea. try clear and rescan list on server too.
These is my settings for client and server:
Note: I use the Trial version :D
  • Wed Dec 01, 2010 12:49 pm
#14 by Prog
You can try install client and server on same PC on first step.
  • Wed Dec 01, 2010 12:59 pm
SubZero
SubZero
#15 by SubZero
Prog wrote:You can try install client and server on same PC on first step.
yes but then the server and client will watch the same channel !!
and if the client change the channel its will change in server too
i think you are not understand what i want :cry:
  • Wed Dec 01, 2010 4:27 pm
  • 1
  • 2
User avatar
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of c
Boofie2010, Sat Dec 13, 2025 2:32 pm
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of cou
Prog, Fri Dec 12, 2025 11:11 am
Playlist sent by pm
Boofie2010, Thu Dec 11, 2025 9:46 pm
  • It is currently Sun Dec 14, 2025 3:25 am
