    • Unanswered topics
    • Active topics
ProgDVB 6.49 - Windows Vista kernel32.dll error
ackwynd
ackwynd
Thu Nov 18, 2010 6:29 pm
#1 by ackwynd
I installed ProgDVB 6.49, and it recently crashed upon install, this was what I got:
(however, the cause of this is always Kernel32.dll).
I did a malware/spyware scan, but no viruses were found, so I don't understand what's causing this.
Any other Windows Vista/7 users had this experience?
  • Sat Dec 11, 2010 11:18 am
SiLencer
SiLencer
Fri Nov 03, 2006 12:10 pm
Re: ProgDVB 6.49 - Windows Vista kernel32.dll error
#2 by SiLencer
No...i´m using Win 7 x64 Ultimate ...its all fine so far ;)
  • Sat Dec 11, 2010 1:14 pm
#3 by Prog
Try reinstall to empty directory.
  • Sat Dec 11, 2010 2:05 pm
ackwynd
ackwynd
#4 by ackwynd
Thanks, this worked, for now anyway. :D
  • Sun Dec 12, 2010 5:40 pm
Установил мобильную ПрогТВ, удалил из папки два шрифта, скопировал свой файл шрифта - не работает. Шрифт в программе обы
kostan, Sat Nov 08, 2025 10:06 pm
If this is what you mean, yes i can send you the file, just tell me how, Thanks. I've sent the logs to the de
nikspk, Sat Nov 08, 2025 7:38 pm
Can you send me logs from "bad" and "good" version from same channel? You can install old version from msi and new
AndresMaxx, Sat Nov 08, 2025 5:48 pm
Can you send me logs from "bad" and "good" version from same channel? You can install old version from msi and new a
nikspk, Sat Nov 08, 2025 4:59 pm
  • It is currently Sun Nov 09, 2025 3:06 am
