    • Unanswered topics
    • Active topics
Prog Dvb 4.92.4 pro on Windows 7
1 post
gsasa
gsasa
Mon Jun 07, 2010 12:14 am
Banjaluka Bosnia and Herzegovina
#1 by gsasa
Hello. On the standard version of Windows 7 ProgDvb 4.92.4 works great. When I try to put the pro version I get an error.
WinLicense
An internal exception occured (Address: 0x77cbfc77) Please, contact prog@progdvb.com. Thank you!
I want to use this version because it is more accessible than 6x versions of screen readers for the blind and visually impaired.
  • Sat Dec 11, 2010 7:32 pm
1 post
Re: Vods
You can try filter in today update. In properties of TV source.
Prog, Sun Oct 26, 2025 11:50 am
Re: ProgTV WinUI3
У меня было такие несколько раз. Какие то ошибки/утечки накапливаются как бы в фреймфорке. Пока нет идей.
Prog, Fri Oct 17, 2025 10:02 am
Re: ProgTV WinUI3
kostan: А после перезапуска глюк пропадает? Да.
kostan, Fri Oct 17, 2025 8:11 am
Re: ProgTV WinUI3
Prog, Fri Oct 17, 2025 7:55 am
  • It is currently Fri Oct 31, 2025 2:06 am
