    • Unanswered topics
    • Active topics
Technisat Skystar usb2 HD CI with irdeto CA & JSC Sport card
alkumiri
alkumiri
Tue Dec 28, 2010 11:51 pm
#1 by alkumiri
I have Technisat Skystar usb2 HD CI with irdeto CA & Aljazeera Sport card (orginal)
If i click Options - Cam-Interface, it says "Waiting for Data ...", but no Data Also the channel not work
how can i make it working ?
I use the latest ProgDVB 6.50.01
My operation system Windows 7 32
  • Wed Dec 29, 2010 12:01 am
Re: Technisat Skystar usb2 HD CI with irdeto CA & JSC Sport
Any problem on other crypted channels?
check Settings->Other->CI = enabled
Check Settings->Device Options=Azurewave
  • Wed Dec 29, 2010 8:18 am
alkumiri
alkumiri
#3 by alkumiri
Free Channel Working but Crypted channels not work
It enabled but didnt work
My Device Technisat Skystar usb2
I tried on other software viewer the cam and card work fine but in Progdvb Pro didnt work
  • Wed Dec 29, 2010 9:05 am
alkumiri
alkumiri
#4 by alkumiri
I changed device options =Azurewave (But my card Technisat Skystar Usb 2 HD)
Now working thanks alot for support
  • Wed Dec 29, 2010 2:18 pm
#5 by Prog
Hm. Is it option not azurewave by default?
  • Wed Dec 29, 2010 2:49 pm
Return to “Hardware”
  • It is currently Sat Jun 14, 2025 3:01 pm
