    • Unanswered topics
    • Active topics
Remote Control: MSI TV @nywhere Satellite Pro
ItsLippiAgain
ItsLippiAgain
Mon Jan 03, 2011 1:29 am
#1 by ItsLippiAgain
Hi,
I just bougt a DVB-S card, and now i am trying the the remote to work.
which plugins, etc do i need?
it is a MSI TV @nywhere Satellite Pro card and the remote control is noname.
i hope you can help me
  • Mon Jan 03, 2011 1:37 am
Re: Remote Control: MSI TV @nywhere Satellite Pro
Check Settings->Device options. Must be selected Geniatech.
  • Mon Jan 03, 2011 8:11 am
ItsLippiAgain
ItsLippiAgain
#3 by ItsLippiAgain
thanks for your answer, i tried it, but the remote control still doesn't work :\
  • Mon Jan 03, 2011 1:03 pm
#4 by Prog
Do you use ProgDVB x32?
  • Mon Jan 03, 2011 1:33 pm
ItsLippiAgain
ItsLippiAgain
#5 by ItsLippiAgain
no, i use x46 because i am using windows 7 ultimate x64
  • Mon Jan 03, 2011 1:38 pm
#6 by Prog
Try x32 for test. You can install to different folder.
  • Mon Jan 03, 2011 2:03 pm
ItsLippiAgain
ItsLippiAgain
#7 by ItsLippiAgain
that also didn't work ... weird ...
  • Mon Jan 03, 2011 2:46 pm
sunnan
sunnan
Wed May 11, 2011 9:08 am
#8 by sunnan
I use ProgDVB x32 now :D
  • Wed May 11, 2011 9:14 am
Return to “Modules”
  • It is currently Tue Jun 17, 2025 12:02 pm
