    • Unanswered topics
    • Active topics
add new channels
franzellin
franzellin
Thu Dec 30, 2010 3:47 pm
add new channels
#1 by franzellin
If I do a new channel search how can I add onlt the new channels without deleting the actual ones?
thanks
  • Fri Jan 07, 2011 4:07 pm
Re: add new channels
You can backup channels directory before that. But scanner not remove channel without addition checks in report.
  • Fri Jan 07, 2011 4:27 pm
You can try prerelase of ProgDVB.
Prog, Mon Dec 15, 2025 4:53 pm
I am not download this list. Really huge list. I change your password in list and use it as crash test:) ProgDVB very sl
Prog, Mon Dec 15, 2025 7:39 am
А лучше ссылку на канал. mkv/mp4 неудобные форматы для записи и всегда будут отличаться тем, что работать хуже чем TS. П
Prog, Mon Dec 15, 2025 7:10 am
running raseberry tv on progd…
i have it running on 2 other windows devices with no problems . i bought a new subscription for a third device and it!s
prop, Sun Dec 14, 2025 11:59 pm
  • It is currently Mon Dec 15, 2025 6:29 pm
