Fresh WinXP-install with Progdvb 6.51.3 Cinergy USB DVB-T (T USB XE MKII) stick, no picture, no log (/debug). When I first (after boot) start original Terratec-software, everything is ok until reboot/shutdown (after hibernate it also still works). Tried with different versions of driver and different renderes - no success. Everything worked BEFORE reinstalling XP. Seems to be an initialization-problem. tried also 6.51.1 und .2. Newest directx 9.
Please help!
Thanks in advance,
olnima
Re: No picture after freh installation WinXP
#3may be forgot .NET?
#4Thanks for reply.
Attached 2 pics, (after short start and quit of the original terratec-software) one before reboot (with filled TV-window), one after reboot (TV-window shows only black).
Thanks,
Olnima
P.S.: .NET is 3.5SP1, played around with every renderer and codec. Seems to be the same problem as described here:
viewtopic.php?f=2&t=5843
Thanks,
Olnima
#5It is looks like BDA problem. Please try other mode in Settings->Device options. For example MS mode.
#6Thanks again for trying to help me. Played around with these settings, no luck, same behavior as in pic "after reboot"
Olnima
P.S.: OS is WinXP SP3 with every update (autom. update-function enabled)
Olnima
#7and again a fresh XP-install -> problem solved...
Only microsoft knows, what happended there. Thanks anyway,
Olnima
Olnima
