EPG problem in v.ProgDVB6.51.4 #1 by mhamoud hi there is problem in arabic epg in v ProgDVB6.51.4 the problem appears in the description only like in the picture i tried previous version ProgDVB6.51.3 , ProgDVB651.2 and ProgDVB6.51.1 and i found the same problem QuoteThu Jan 27, 2011 2:12 pm
Re: EPG problem in v.ProgDVB6.51.4 #2 by vsoftpk_1 does any body have solution of this problem? - definitely no ads here - QuoteSun Jul 17, 2011 4:01 pm
Re: EPG problem in v.ProgDVB6.51.4 #3 by V.Zhukoff it is a problem of the script . Or a code page . Be sure that u have this fonts which EPG provider needs. And may be wrong WIN settings (multi language ) [size=50] Железо: Acer KG271C, IP Q G2020@2.9, HD7770, 8 RAM, AMD audio, Yamaha RX-V465, LG 42LA790V, Prof 7300,7301, Tevii s470, TBS 6922se. Софт: W7x64, ProgDVBx32. Настройки: prog demux, audio-AC3Filter, WASAPI, video-Custom EVR, ArcSoft 2,28,497 [/size] QuoteSun Jul 17, 2011 4:20 pm
Re: EPG problem in v.ProgDVB6.51.4 #4 by Prog Yes, it is looks like font problem. Try change OSD skin. QuoteWed Jul 20, 2011 11:07 am
