Hello,
I found a behavior on ProgDVB pro (6.51.04 currently) wich i think is not correct.
Setup: Skystar HD with 10 port Diseqc 1.1 switch.
After a program crash there is a posibility that the receiver card is left in an non-functional state.
If ProgDVB is restarted, the adapter gets disabled in TV sources, because the device is not available.
After computer restart, when i re-enable the device, all Diseqc settings are lost and the complete switch and satelite configuration has to be done again.
Isn't it possible (or should it not be possible) to keep the satellite setup from before the startup when the device becomes disabled (It happens on every startup failure...)
Thank you.
LE: just got another small bug: If you enter TV Sources and then cancel, the program hangs and has to be closed and restarted.
																					Diseqc settings lost after restart with DVB device not avail
#1Skystar HD on Core2 Duo 6420
With ProgDVB Professional of course :-)
