SkyStar HD problem (ProgDVB doesn't recognize the device)
arturrol
arturrol
Fri Jan 12, 2007 9:23 pm
#1 by arturrol
Hallo,
I have just installed Skystar HD with the latest BDA drivers from Technisat.
Unfortunatelly ProgDVB 4.81 can't recognize the device. ( I can't start any DVB-S BDA device from the device list)
Does anybody has a clue or an advice?
Best Regards
Artur
Original software -"Technisat TV Center" works perfectly but no plugins(PMCAM) are accepted.
  • Fri Jan 12, 2007 9:54 pm
arturrol
arturrol
Version 4.81.1 recognize perfectly the device but...
#2 by arturrol
Version 4.81.1 recognize perfectly the device but still program has a hiccup (hang up for a while -1/4 sec and one second works fine in relays). But picture is fluent. Try to hold a ProgDVB window frame by mouse pointer and move around. Any Ideas. Dvb Dream behave the same way...
Regards
  • Thu Jan 18, 2007 8:22 pm
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 11:38 am
