Hello,
im using Windows 7 Professional 64 bit.
Device is Technotrend S2-3600
When im Running the latest ProgDVB as 64 Bit it runs fine without problems.
If im running ProgDVB 32 bit (cause of my plugin wich is only 32 bit) it won't start.
Im always getting the error message that adpsi30.dll and DWUSBAPI.dll are missing.
I reinstalled already the Drivers for my Technotrend Device and reinstalled ProgDVB.
Also i started ProgDVB with Administration rights and in compatabillity mode
So what to do ?
Thanks for you help in advance!
Re: ProgDVB 6.63.6 32bit always Crashes
#2Please send screen of TV Sources and device options.
Also try without plugin
#3Enclosed the screens.
I tried without the plugin, nothing changes.
http://img135.imageshack.us/img135/6989/progdvb1.jpg
http://img853.imageshack.us/img853/5632/progdvb2.jpg
http://img843.imageshack.us/img843/7980/progdvb3.jpg
#4I am getting the same errors. I have a Tevii card. It has been working fine for a long time until now.
#5I have the same problem.
adpsi30.dll missing
DWUSBAPI.dll missing
I use a technotrend s2-3600 dvbs2 usb box.
first it asked me to reregister it. After that I get the errors shown above.
32 bit progdvb. using win7, 64bit.
I'm back to the old version 6.25.03.
What''s going on????
adpsi30.dll missing
#7Not so much as a crash but the screen will freeze quite often, changing channel brings it back.
Changing channels can be very slow sometimes and can causes what ever else I have running to pause.
6.63.7 is faster at changing channels but I still get the picture freeze.
#8I take back what I said about it being faster, it's about the same, but for some very strange reason if I run "Piniforms Defraggler" tool at the same time, channel changing is a lot faster. It could just be anything which does disk access speed it up. Strange!
Anyway time for bed, work in the morning.
#10Timeshift was already set to memory, disabling does not seem to make a difference.
When moving from one satellite to another the status bar and channel selected do not changes until after the satellite is reached, i.e. no DiSEqC countdown, the picture just appears and then the channel name changes. Not the other way around as it was in pre 6.63.x.
#11Hello,
after using 6.63.7 from prerelease and deactivating Timeshift its running fine.
Now im ready to buy the Pro Vers.
#12I have now gone back to using 6.61.2
