    • Unanswered topics
    • Active topics
A new 16/32 APSK tuner supports VCM,CCM,ACM
1 post
dodo2013
dodo2013
Fri Jun 17, 2011 1:15 am
#1 by dodo2013
A new Tenow Card TBS6925, supporting blind scan and 32APSK Demodulator, it also supports CCM, VCM, ACM mode, supports multiple Transport Stream receiving, supports Generic Stream capture, and supports up to 190 Mbit/s channel bit rate capture.
It's fully compatible with windows 7 Media Center and ProgDVB, DVBDream, DVBViewer, DVBlogic, Skynet, TSreader…
  • Fri Jun 17, 2011 1:29 am
1 post
Установил мобильную ПрогТВ, удалил из папки два шрифта, скопировал свой файл шрифта - не работает. Шрифт в программе обы
kostan, Sat Nov 08, 2025 10:06 pm
If this is what you mean, yes i can send you the file, just tell me how, Thanks. I've sent the logs to the de
nikspk, Sat Nov 08, 2025 7:38 pm
Can you send me logs from "bad" and "good" version from same channel? You can install old version from msi and new
AndresMaxx, Sat Nov 08, 2025 5:48 pm
Can you send me logs from "bad" and "good" version from same channel? You can install old version from msi and new a
nikspk, Sat Nov 08, 2025 4:59 pm
  • It is currently Sun Nov 09, 2025 3:52 am
