additional idea
hi Prog ( Dr-Soft )
I got the idea of this program and
There are many people want this application
This is a false picture of the application just to see the form design you can use your own design
You can make it free or with money
In the end, I hope you success
Re: additional idea
That is for detection transponders from NIT? I am not sure. Because if cable or this satellite have good NIT table then table of transponder not important. And software need only detect fist transponder with NIT.
